JLU_Design Posted June 3, 2022 Share Posted June 3, 2022 Does someone know why when I click to turn off the Eave Fascia it also turns off the Gable Fascia? I would like to turn off the Eave Fascia and leave the Gable Fascia on. It would seem that because they both have a check box it would be possible to deselect one without affecting the other. I'm on x14 now. Just upgraded, but I don't think that's the reason for the issue. Link to comment Share on other sites More sharing options...
JLU_Design Posted June 3, 2022 Author Share Posted June 3, 2022 35 minutes ago, solver said: That dumbness has been there forever. You can make the eave fascia 1/16"x1/16". Thanks for the reply. At least I know that it's not something I'm doing wrong. I Don't like the way Chief uses the outside edge of the finish fascia for the start of the roof plane. So I all the sudden had the idea to just turn the fascia off which would then make the roof plane start at the sub-fascia then I would just use a Shadow Board for the eave fascia. Looks like Chief wins again. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 4, 2022 Share Posted June 4, 2022 sometimes I will use the sub-fascia as the fascia bd. 1 Link to comment Share on other sites More sharing options...
