Joe_Carrick Posted June 1, 2022 Share Posted June 1, 2022 I have some Pony Wall Configurations that I've added to the Library. However, Chief doesn't properly store the "Height above Floor" of the Lower Wall. So when one of these is added to a plan they are not the same as when they were created. I've reported this via customer support and the problem was confirmed. For now, I've opened the Library Object(s) and set the "Height above Floor" of the Lower Wall. This eliminated the problem so if anyone is having this trouble with saved Pony Walls, that's how to fix it. It's really a bug that CA should fix. Pony Walls saved in the Library need to match what was created. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 1, 2022 Author Share Posted June 1, 2022 Maybe, but for now I'm just posting it here as "General Info". I'm also finding that some saved walls don't always come into a plan with their saved materials. Actually, I find that this is only true when there's a "Room Style Pallet" that has a defined Wall Material. In that case the upper and lower wall finishes are assigned the Room Wall Material instead of there own materials. That's a bug which I will report. 1 Link to comment Share on other sites More sharing options...
