AndrewSopher Posted May 25, 2022 Share Posted May 25, 2022 Is there a way to get your vertical dimension to face horizontally (image 2 is what I want and image 1 is the way it is before manually rotating the number) instead of it rotating with the plan. I tried both settings in the dimension defaults for rotating with plan and it did not change the direction of the number. I know you can rotate each dimension number manually, but I was wondering if there was a better and faster way to do this. Thanks. . Link to comment Share on other sites More sharing options...
joey_martin Posted May 25, 2022 Share Posted May 25, 2022 I doubt it can be done automatically. The CAD standard are for vertical dims to be read from the right side of the page. Link to comment Share on other sites More sharing options...
AndrewSopher Posted May 25, 2022 Author Share Posted May 25, 2022 1 hour ago, joey_martin said: I doubt it can be done automatically. The CAD standard are for vertical dims to be read from the right side of the page. Figured that was the case, thanks. Link to comment Share on other sites More sharing options...
