winterdd Posted May 23, 2022 Share Posted May 23, 2022 I have an engineer who wants this fixed. Zoomed in it is fine, zoomed out it grows. I have noticed this from day one with CA but overlook it. Why does this happen? zoomed in zoomed out and printed Link to comment Share on other sites More sharing options...
Chopsaw Posted May 23, 2022 Share Posted May 23, 2022 Do you have Line Weights or Print Preview turned on in your section view ? Link to comment Share on other sites More sharing options...
winterdd Posted May 23, 2022 Author Share Posted May 23, 2022 14 minutes ago, Chopsaw said: Do you have Line Weights or Print Preview turned on in your section view ? negative zoomed in close zoomed out Link to comment Share on other sites More sharing options...
Chopsaw Posted May 23, 2022 Share Posted May 23, 2022 9 minutes ago, ChiefUserBigRob said: 26 minutes ago, Chopsaw said: Do you have Line Weights or Print Preview turned on in your section view ? negative Yes so that seems to be the issue. You can't print without line weights being displayed so you need to check how they will print by turning on Print Preview or Line Weights and then make your adjustments. 1 Link to comment Share on other sites More sharing options...
winterdd Posted May 23, 2022 Author Share Posted May 23, 2022 Thanks for the help chop! Link to comment Share on other sites More sharing options...
