Layout space converting to metric instead of imperial
jenmarsch
5 minutes ago, jenmarsch said:
There is no option to change it to feet in drawing sheet setup either.
Ok something did change on you then.  The dropdown list only displays your default units so you will need to go back to Preferences > Unit Conversions and make "ft" or " ' " a default unit.   Then it should all work as normal.
