binkpear Posted May 19, 2022 Share Posted May 19, 2022 I am struggling with creating the attached detail in Chief X13. I have tried creating a pony wall but it cuts off my main wall and does not extend down to cover the face of the monolithic slab. I don't need to show the under slab detail of foam and rock, mainly want a way to do renders and ideally cross sections. Any help would be most appreciated! Chief help.pdf Link to comment Share on other sites More sharing options...
GeneDavis Posted May 19, 2022 Share Posted May 19, 2022 Please do future pics as attachments so we don't have to download them into our PCs. Like what I did here with yours. Consider doing the detail using a stacked molding. By stacked, I mean a molding with all the elements in the cluster. The counterflash above. The steel siding. Battens. Foam. Build with the framed wall and thickened-edge slab with foam under, then build up the molding and apply. You can do versions of the molding differently to address doors. You can break the molding polyline and not have the molding at segments where needed. Maybe watch some training videos about molding polylines and built-up moldings. 1312248009_Chiefhelp.pdf Link to comment Share on other sites More sharing options...
