Modify 3D Object
sonoferin
I purchased a sports 3d package intending to use the basketball court for a housing complex. They only require a 1/2 court.
I cannot for the life of me figure out how to only show 1/2 of this court that comes in this package.
Any Ideas ?
Thank you
Edited by sonoferin
That looks like it is from a Chief library.
First off, it is not a symbol, it is an architectural block.
Create a Terrain and place the basketball court on the terrain.
You wont get the lines or court to display without a terrain because the lines are Road Markings and need the terrain to work.
Select the basketball court architectural block and explode it using Explode Architectural Block tool on the Edit toolbar.
You can then edit the various Road Markings and court size.
The baskets and posts are 3D symbols that are contained in the architectural block so you can select them and use the normal symbol editing tools on them.
I have only done part way in this pic to give you an idea.
  • Upvote 3
