tantrim Posted January 13, 2015 Share Posted January 13, 2015 I am missing something probably very simple, but if anyone can set me straight I would appreciate it very much. I have a kitchen that I have build a breakfast seating on the back side of some cabinetry using a half wall and adjusted my height to 40.5" so my countertop would finish at 42" elev. I first used a regular wall and adjusted the height from my wall elevations but it left me with a void in my ceiling finishing. when using the half wall I can not seem to figure out why it does not finish the end of the wall with drywall, the plan view shows it to have the drywall but when viewing it in the render it is not showing, leaving the framing exposed only on the end. One other thing is that the wall it ties into perpendicular which is a full height wall to the ceiling is also affected by this in the same nature. Now there are is a walkway to the left of the half wall that I used a room divider to separate the kitchen from the dining room and where the half wall ties into the full wall there is also another room divider that id being used to divide the dining room and living room apart from each other. I added this bit of information just incase the room divider was causing this issue. I have removed the room dividers and it made no difference however. Ted Antrim American Finishers, Inc. Link to comment Share on other sites More sharing options...
evergreen Posted January 13, 2015 Share Posted January 13, 2015 post the plan Link to comment Share on other sites More sharing options...
ACADuser Posted January 13, 2015 Share Posted January 13, 2015 Tough to say without a plan file to test but try removing the room divider, make the wall extend through & use an OPENING to get the area next to the cabinet open. Link to comment Share on other sites More sharing options...
MikeJG Posted January 13, 2015 Share Posted January 13, 2015 You could also try playing with the 'Edit Wall Layer Intersections' tool. It allows you to 'drag' the sheetrock around the unfinished part of the wall. I've not had 100% success with it though. You can get to it by right-clicking on the wall. Link to comment Share on other sites More sharing options...
