Robboulton Posted May 3, 2022 Share Posted May 3, 2022 Can anyone help regarding the issue I'm facing when trying to draw an existing loft conversion. The exterior walls don't stop at the roof. I have created a 3rd floor but kept the roof at the floor below. I tried the same but lowering the roof after adding the floor but the same thing happens. Eventually it will have ashlar walls front and rear (knee walls I think you call them across the pond...). Pic 1 shows before, Pic 2 shows after. You can see the issue. Plan attached if it helps. Thanks in advance. Pic2.pdf Pic 1.pdf 20220420 - Taylor Existing.plan Link to comment Share on other sites More sharing options...
MPDesign Posted May 3, 2022 Share Posted May 3, 2022 Raise the roof planes 50mm, they are too low for the roof framing to sit on the 3rd floor framing. 1 Link to comment Share on other sites More sharing options...
Robboulton Posted May 3, 2022 Author Share Posted May 3, 2022 As simple as that. Thank you sooooo much! Link to comment Share on other sites More sharing options...
MPDesign Posted May 3, 2022 Share Posted May 3, 2022 Your welcome Link to comment Share on other sites More sharing options...
Robboulton Posted May 3, 2022 Author Share Posted May 3, 2022 Will do thanks. Link to comment Share on other sites More sharing options...
