Way to bring in materials pricing from supplier
cbucks
You can export and import a custom or default list between plan files but I don't think you will be able to achieve any sort of a direct live link with excel unfortunately.  You can export your material list to excel and add the prices and do your calculations but getting it back into the program is the issue without breaking the link.
You could do a little more research into the file format (.calumber ) but it is most likely as it appears "Chief Architect Lumber " and proprietary formatting.
