KnotSquare Posted April 21, 2022 Share Posted April 21, 2022 The left hand railing of the entry stair is causing a break in the wall on the 2nd Level. I can move it over and this changes, showing this to be the case. I tried moving the room divider to the bottom of the stairs thinking that would define the rail height out there, but it just creates other problems. Peck Columns for Library.plan Link to comment Share on other sites More sharing options...
KnotSquare Posted April 22, 2022 Author Share Posted April 22, 2022 I think I got it fixed, but I still do not understand the cause. Link to comment Share on other sites More sharing options...
robdyck Posted April 22, 2022 Share Posted April 22, 2022 It's the roof plan. Just switch to manual editing to clean up the roof planes at that corner. Link to comment Share on other sites More sharing options...
KnotSquare Posted April 23, 2022 Author Share Posted April 23, 2022 Thank you. I try to do everything, at least until the very end with Autobuild roofs. I actually use the Materials List and count on it framing correctly, walls and all. This will require a manual build of the independent roof over the Sitting Room, but I hope that all else can be built with Autobuild. MFr (yah, my mother caused that) Link to comment Share on other sites More sharing options...
