Inset corner cabinets- remove stile between double doors?
Connecticut
Go to solution Solved by MarkMc,
Is there a way to eliminate the stile between the double doors on a corner cabinet with inset doors?
I believe I have exhausted the dialog boxes on the cabinet, including making the doors auto left or a double door.
Center stile on double doors is unchecked.
Using Chief Premiere version 12.  Thanks for any insights.
  • Solution
No, long time issue- need to make from 2 cabinets, easier in X13 or 14 BTW. The narrower cabinet has to either overlap the first one or use custom shelf symbols that don't resize.
Did this on the fly ( faster than finding an old plan with one in 12) so not exactly up to snuff but you can get the idea..image.thumb.png.1fd6e889cb7bd81ff4aadb1610569402.png
corner cab.zip
  • 2 weeks later...
