timmy123 Posted January 12, 2015 Share Posted January 12, 2015 Hi all, I need to make the dimension labels transparent. See the attached image I am not able to see my grid thru my dimension labels. I can make the Text labels easily transparent by setting the fill as transparent. But how can I accomplish the same with the dimension labels? Thanks, Tim Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2015 Share Posted January 12, 2015 I think you need to redefine your Text style or use "Custom Text Style" and check the transparent radio button in Defaults>Dimensions>Dimension , seems to change existing dims as well when I just tried it....using the custom setting but see what others have to say I am no expert on text styles Link to comment Share on other sites More sharing options...
