Substance player
Gawdzira
The Wood Builder has a seamed shiplap option but it was made to intentionally smooth out the seams lengthwise, but you can get pretty close using the hardwood Setting...Here's the settings I used to get close
Usually from here I'd say...
-Bring it in Chief
-Rotate it 90°
-Load you roughness map into your texture slot and get your pattern with the "Pattern from Texture" button then load your texture back in the texture slot
-Set your scale how you want it
BUT while testing it out I ran into a couple snags with scaling the pattern from texture so I just made a quick one for you that hopefully should work.  We'll get those snags looked at so next time you can do all this yourself but for now see attached for my example and hopefully that will help you out.
Let me know if you have any questions or if something didn't work out for you.
Shiplap Example.calibz
