Imported New Layer template not showing content in the Active Layer Sset Ccontrol
josephbupe
Hello everyone.
I want to continue using a New Layer template from CA X12 which give me my preferred design style. So I manually imported it into CA Premier X13, but I noticed when I open a new layer from the template the Active Layer Set Control does not show the options for saved layers(doesn't show the working plan view, etc), it only shows NONE.
The imported template is call Urban_Chic_Contemporary_CA_X12
I would appreciate your help.
1 hour ago, josephbupe said:
Hello everyone.
Were you using saved plan views in x12?  If you were import the saved plan views as well and you should sync up.  That is if I am understanding your issue correctly.  Pictures speak a thousand words most of the time.
