josephbupe Posted March 10, 2022 Share Posted March 10, 2022 Hello everyone. I want to continue using a New Layer template from CA X12 which give me my preferred design style. So I manually imported it into CA Premier X13, but I noticed when I open a new layer from the template the Active Layer Set Control does not show the options for saved layers(doesn't show the working plan view, etc), it only shows NONE. The imported template is call Urban_Chic_Contemporary_CA_X12 I would appreciate your help. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 10, 2022 Share Posted March 10, 2022 Simplest thing is to simply open the X12 Template in X13 and save it in your X13 Template Folder. That should bring everything with it. You will of course need to relink all referenced files with X13 versions. Link to comment Share on other sites More sharing options...
rgardner Posted March 10, 2022 Share Posted March 10, 2022 1 hour ago, josephbupe said: Hello everyone. I want to continue using a New Layer template from CA X12 which give me my preferred design style. So I manually imported it into CA Premier X13, but I noticed when I open a new layer from the template the Active Layer Set Control does not show the options for saved layers(doesn't show the working plan view, etc), it only shows NONE. The imported template is call Urban_Chic_Contemporary_CA_X12 I would appreciate your help. Were you using saved plan views in x12? If you were import the saved plan views as well and you should sync up. That is if I am understanding your issue correctly. Pictures speak a thousand words most of the time. Link to comment Share on other sites More sharing options...
