Manual Roof Issue
No1ZZTopfan
Go to solution Solved by No1ZZTopfan,
Having a bit of trouble. Created this shed with manual roof planes to match an existing shed but when I changed the gable & eave depths from 7 1/4" to 2 1/4" this happened. I can't seem to find the settings to fix the openings or gaps. What am I missing? Thanks in advance.
  • Solution
1 hour ago, solver said:
You forgot to attach the plan file.
No, I didn't. I wanted to see if I could find a solution without doing so. My apologizes. However, I was able to figure out the issue. By changing the structure thickness in each of the manual roof planes. See attached.
Edited by No1ZZTopfan
