Evolution Posted January 6, 2015 Share Posted January 6, 2015 I used the lowered ceiling option, for areas where I need the ceilings lower than the floor to floor height. At the stair from the basement up to the main level, how do I get the ceiling to frame around the stair (in stead of showing the air space). I drew a invisible wall around the stairs but that didn't work. Do I need to use a soffit? Link to comment Share on other sites More sharing options...
CJSpud Posted January 6, 2015 Share Posted January 6, 2015 Have you tried using the auto stairwell tool? It will create the hole in your floor above the stairs. You can then edit the hole location if needed. Link to comment Share on other sites More sharing options...
