Half Plumbing Wall with WIndow
Design_GBH
Go to solution Solved by SH_Canada,
Hi there, this is my first time posting so I hope I do it right.
I am trying to put a half plumbing wall against a 2x6 exterior wall and put a window above the height of the plumbing wall, but in the exterior wall. For some reason every time I put the half wall against the exterior wall it hides the part of the wall that is under the window, but is perfectly fine in 3D view. Does anyone know how to fix this?
The half wall is 40" tall and the bottom of the window is 42".
I am using Premier X13 on windows.
25 minutes ago, Gawdzira said:
I would fake that wall with a polyline. Do you really need the lumber list the actual wall will produce? The other option would be to make that section of wall 3.5" thicker and make it a pony wall. But really, the polyline.
I tried adding the extra 2x4 to the 2x6 wall as a pony wall but found that I had the same problem unfortunately. I was thinking about the polyline but was hoping that there would be a better way. Thanks!
