Selecting posts in post-frame building
madcowscarnival
Is there a way to create a group out of the post and footing in a post-frame building without grouping as CAD block?  The file I'm working with, when grouping the posts and footings, loses the post data in 3-D view and only shows the footing.  It "might" have also not allowed the dimensions to identify the post as an object to locate (though I had some dim settings wrong).  The post only shows back up after unblocking the CAD object.
I'm just trying to make it a little easier to select and move around post&footing without tab-selecting the post, then ctrl+click the footing (or CAD block, select, unblock).  Other than this rather minor "issue" Chief is letting me put together a post-frame layout nice and quick.
