K-Lynn Posted January 28, 2022 Share Posted January 28, 2022 Is there a way to rebuild the foundation without losing the design I have already done? I need to change the stem walls from 10 ft. to 9 ft. If I select the bedroom room spec the stem wall height is grayed out. The living space stem wall height could be changed in the room spec. Link to comment Share on other sites More sharing options...
joey_martin Posted January 28, 2022 Share Posted January 28, 2022 Sounds like you have a ceiling hgt issue above that bedroom. You should be able to just select the rooms and change the foundation accordingly. Make sure you are doing from the foundation level, and not an upper level. Link to comment Share on other sites More sharing options...
joey_martin Posted January 28, 2022 Share Posted January 28, 2022 If the default is changed and foundation rebuilt everything on that level will be lost. Best to do it room by room. Link to comment Share on other sites More sharing options...
K-Lynn Posted January 28, 2022 Author Share Posted January 28, 2022 Thanks for the responses. I do have the defaults set but that did not change anything. I have gone room by room and where I can change the stem wall it is working. The bedroom, bath & closet all have remained grayed out for the stem wall. I have looked at it in 3D and cut a few sections and can't find anything wrong with the ceiling. The ceiling height is the same throughout the basement. Oddly, the wall has moved up but the slab is staying down at the bottom of the footing in those rooms. ??? Link to comment Share on other sites More sharing options...
K-Lynn Posted January 28, 2022 Author Share Posted January 28, 2022 Thanks, that is a time saver! I realized I needed to adjust the stem wall ht. in all floor levels in the defaults. (not just foundation) Then I reset the floor and ceiling hts. for all floors and it worked! Thanks for the tips! Link to comment Share on other sites More sharing options...
