divreig Posted January 26, 2022 Share Posted January 26, 2022 I wanted to know if there was any way to force the railings place posts at 8" OC rather then evenly dividing them based on the wall length. For example, if I have my post spacing set at 96" and my railing is 10' long chief will place the posts 5' on center. I would like give me a post at 8' then at 2'. I have added pics of the setting i thought was supposed to control. holly.planFetching info... Link to comment Share on other sites More sharing options...
Chopsaw Posted January 26, 2022 Share Posted January 26, 2022 If the railing is reversible, symmetrical on both sides you can simply place a wall break at 2' and then reverse one of the two sections and it should hold that way with a Newel Post at 2'. Otherwise you would need to place as short room divider perpendicular to the railing. Link to comment Share on other sites More sharing options...
divreig Posted January 27, 2022 Author Share Posted January 27, 2022 ok good idea thanks!! Link to comment Share on other sites More sharing options...
