Arched Door Casing Headache
KySlabdaddy
  On 1/17/2022 at 4:02 PM, KySlabdaddy said:
I updated my signature, Let me know if any other info needs to be listed. I am new to this forum. Thanks for your instructions
Thanks Chopsaw, worked like a charm!!
Rob here is link to doors from Chief 3D Library.
https://hometalk.chiefarchitect.com/gallery/image/616-doors-no2
Expand
Welcome to the forum....many experienced and helpful people in here. I have learned a lot thru CA vids and forum help.....
I will admit, I wondered the same thing when I first saw a rectangular door panel in an arched door in Chief. Hopefully I can give some insight into that.
Chief will not match the door shape to the symbol used for the door panel. It will match parametric door panels to the door shape.
For example, what type of arch should be used with this door panel? While this is obviously a contrived example, Chief would have to give an answer if it was going to use the symbol shape, since a symbol can be absolutely any shape.
