3D_Russ Posted January 3, 2022 Share Posted January 3, 2022 I've been tediously going through my entire list of doors and windows and changing the trim width for each job I draw (if it's different than my template). I click on each door type and window in the Default Settings. Is there a way to globally change all of them at the same time? I thought I read somewhere that this would be an option on one of the last versions. Link to comment Share on other sites More sharing options...
rgardner Posted January 3, 2022 Share Posted January 3, 2022 (edited) 4 hours ago, 3D_Russ said: I've been tediously going through my entire list of doors and windows and changing the trim width for each job I draw (if it's different than my template). I click on each door type and window in the Default Settings. Is there a way to globally change all of them at the same time? I thought I read somewhere that this would be an option on one of the last versions. In your defaults you can group select all similar door types and change your casings at the same time. That with windows uou can do the same. For base chair rail and crown you can change it by room type or by floor. Edited January 4, 2022 by rgardner Link to comment Share on other sites More sharing options...
3D_Russ Posted January 3, 2022 Author Share Posted January 3, 2022 Thank you!! SO simple!!! Don't know why I've missed that little trick. Link to comment Share on other sites More sharing options...
