Steve_Nyhof Posted November 29, 2021 Share Posted November 29, 2021 When I set the roof structure thickness to 7.25, the roofs are still generated at 3.5 https://www.loom.com/share/58d662203eb545dfb7acf75239cde336 Thoughts? Thank you, Steve Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 29, 2021 Author Share Posted November 29, 2021 It's a new drawing and I only have the two roof planes which were auto generated from the defaults. Set to 7.25, generated to 3.5 Link to comment Share on other sites More sharing options...
Chrisb222 Posted November 29, 2021 Share Posted November 29, 2021 22 minutes ago, stevenyhof said: When I set the roof structure thickness to 7.25, the roofs are still generated at 3.5 https://www.loom.com/share/58d662203eb545dfb7acf75239cde336 Thoughts? Thank you, Steve You have "trusses" checked in the Build Roof DBX. That will override the Structure value and instead use the setting in the Framing Default, Trusses which I suspect is set to 3-1/2". 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 29, 2021 Author Share Posted November 29, 2021 22 minutes ago, Chrisb222 said: You have "trusses" checked in the Build Roof DBX. That will override the Structure value and instead use the setting in the Framing Default, Trusses which I suspect is set to 3-1/2". Ah!! Thank you very much! Link to comment Share on other sites More sharing options...
