Mansard Roof and Dormer Help
aurorainteriors
Go to solution Solved by Kbird1,
I have a whole house remodel I am working on that has a finished attic space so it is important for my roof to resemble what they currently have. I'm attaching photos of the existing house exterior photos from google maps to show what the roof looks like (I know these are not clear but I currently do not have additional photos to reference).
It appears to me to be a hip roof from the front but now I'm thinking after reviewing the photos again it is a mansard roof which I cannot figure out how to create.
Additionally, there is supposed to be a dormer in the attic and I just cannot figure out how to appropriately place the dormer without getting an error message. Any advice would be greatly appreciated as roofs are not my specialty in this program by any means.
File is also attached.
Thanks in advanced.
1393016004_model1.thumb.PNG.ffb918a4f0beec5dae339e8b2688fb5e.PNG1377089628_roof1.thumb.PNG.ad05746d91f174afa53d141602872b64.PNG10941843_roof2.thumb.PNG.b6c48900d467025811484e089e5cb791.PNG
roof 3.PNGForum Copy.plan
I'm using Chief Architect Premier X12
To me it appears to be what Chief Calls a Gull Wing Roof , or 2-Pitch Roof  , opposite Pitches of a Mansard.
Low to High ie:  4/12 , then turns into 8/12 approximately 42-48" from the Baseline ( Wall )
As Eric shows above.....   Build Roof > Roof Styles > Gull Wing Roof  which should open the Help file for you...
Low to High ie:  4/12 , then turns into 8/12 approximately 5' from the Baseline ( Wall )
I drove past the house today and the roof is a combination of the Gull Wing and Mansard because the side walls do not come to a peak like a gable. Trying to figure out how to do this. When I follow the steps for the mansard roof it comes up to a point (I attached a screenshot) and I don't know how to make it flat on the top.
No extra Photos taken?
as it appears to be a ridge running left-right and not a flat Roof in the Pics above.....
Do you know the real Roof Pitches ?  here is my quick go at the gullwing , all numbers are guesses
Here's a bird's eye view of the house. Unfortunately my clients haven't closed on the house yet and original owners were outside so I did not want to walk up to their property without permission and take photos.
  • Solution
Ok , that helps , it's still a Gull Wing but it appears they had to make the top almost Flat ...to perhaps met a local height restriction?
You will need to build the Gull Wing, turn off Auto Roof Build, then Manually add the 4 almost flat ( 1/2" : 12 ?) triangular Planes.
Mick.
* I did this is a new Plan as your Plan is having issues with the Gull Wing Roof for some reason.....
image.thumb.png.f20981348b2175fcde74f0523e7c4355.pngimage.thumb.png.970e8120e088efdeba1ca0d208687ea1.png
image.thumb.png.e73998d30c60a48ea5026e681aee96ee.pngimage.thumb.png.fbdbaa9048c10b0c42be1b8aa5920e83.png
Mick.
This is so extremely helpful! Thank you for explaining how to do this. I've worked on this for hours trying to figure it out.
