Ryno300 Posted November 16, 2021 Share Posted November 16, 2021 Hello everyone. New Chief user here, 15 years on Softplan and trying to convince the office to take the leap. Anyway, has anyone else come across this where it essentially looks like the exterior surface of the walls has a butt joint instead of mitering? These are just the default walls that come with Chief and thought it was maybe the new line drawing on top feature but it also shows in Vector where that isn't an option... Link to comment Share on other sites More sharing options...
Chopsaw Posted November 16, 2021 Share Posted November 16, 2021 That is not typically what happens although it can most likely be fixed with the Edit Wall Layer Intersections tool. Actually I am not quite sure how that happened if it was auto built. Are the intersecting walls defined the same way ? 1 Link to comment Share on other sites More sharing options...
Ryno300 Posted November 16, 2021 Author Share Posted November 16, 2021 Yea that is what I was thinking and can’t seem to find anything that would cause it. Does it on siding walls as well but is only the width of the exterior layer. I messed with the layer intersection tool and it still shows despite everything mitering with that tool. Like you said though it’s just out of the box walls, auto roof/foundation and a quick square house. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 16, 2021 Share Posted November 16, 2021 If you want to post the plan file I will see if there is something obvious causing that to happen. I just can't think of it off hand but I can compare to my test plan and something my become evident. Link to comment Share on other sites More sharing options...
Ryno300 Posted November 16, 2021 Author Share Posted November 16, 2021 So I figured out it’s something on my template file, I have a suspicion it is something to do with my foundation settings. It works just fine if I just use a fresh new plan file instead of my template. On my phone at the moment but will upload a plan file in the morning if I still can’t figure out what it is exactly. Thanks for the help! Link to comment Share on other sites More sharing options...
