ChiefJeet Posted November 9, 2021 Share Posted November 9, 2021 I have built 2nd floor and a roof with "Ignore upper floor". I have then built the attic walls and designated the roof void as attic space In the section view, the attic area should not have floor but a ceiling platform. Any easy solution to this please? Floor in attic.plan Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 9, 2021 Share Posted November 9, 2021 You need to "Open" the attic rooms and modify the structure tab to eliminate the "floor sheathing". I'm not sure what you mean that the attic areas need a "ceiling platform". Link to comment Share on other sites More sharing options...
ChiefJeet Posted November 9, 2021 Author Share Posted November 9, 2021 1 hour ago, Joe_Carrick said: You need to "Open" the attic rooms and modify the structure tab to eliminate the "floor sheathing". I'm not sure what you mean that the attic areas need a "ceiling platform". The structure between 2 floor is a floor and should use construction specified in the floor structure. The space between the room below and the roof above is a ceiling and should use the construction specified in ceiling structure. 1 hour ago, solver said: You want the attic space to use the ceiling framing from the room below as its floor? Maybe because the joist are different size? The ceiling joist would have smaller joists sizes. Link to comment Share on other sites More sharing options...
ChiefJeet Posted November 9, 2021 Author Share Posted November 9, 2021 Ok. Got it. Can change manually. I thought that it was an automatic process. Thanks both. Link to comment Share on other sites More sharing options...
winterdd Posted November 9, 2021 Share Posted November 9, 2021 1 hour ago, Joe_Carrick said: You need to "Open" the attic rooms and modify the structure tab to eliminate the "floor sheathing". I'm not sure what you mean that the attic areas need a "ceiling platform". what I would have done too...... Link to comment Share on other sites More sharing options...
