Adding an octagon center post in gazebo roof and ceiling
Elliot
I am drawing an 18' diameter gazebo and although I have most it drawn I have found an item that has me stumped. I want to add an 8 sided post 7.5" diameter that goes from the peak of the second roof for the cupola though the main roof and hangs below the ceiling about a foot. The bottom foot will have a turned large finial on it.  Each rafter and joist will end on the center octagon post.  I need help figuring out how to get Chief to draw that. Also I keep trying to place the weathervane  from the library on top of the peak but it doesn't show up. And I want to add venting in the 20" tall fascia for the second roof but can't figure that one out either.
thanks for your help.
   Gesang Gazebo 3d2.pdfFetching info... Gesang Gazebo 3d1.pdfFetching info...
Eric
thanks. that was so simple. I have the octagon post in place, with the finial below, and the weathervane.
still working on the vents in the cupola walls. and I tried a jpg file which worked instead of a pdf.
39037166_Gazebowithfinialandpost.thumb.jpg.f4f0aeb41b535e7b2f971ce1533884a0.jpg1770576578_Gezebo3d1.thumb.jpg.fa10d2d796046d298d3dfb359673ffa3.jpg320348391_Gazebo3d2.thumb.jpg.91738fe678bb4aab284c958bbeebb812.jpg
  On 10/17/2021 at 11:44 PM, solver said:
Make an 8 sided pyramid, trace the outline, convert to a Polyline Solid.
Expand
Probably too late now, so just a heads up for next time.
It is easy to do this sort of thing with the Regular Polygon tool.
463941631_ScreenShot2021-10-18at1_18_18pm.thumb.jpg.bbcae41299f07f1739ece41c5af3ff0e.jpg
There is also a similar tool for the walls.
655427127_ScreenShot2021-10-18at1_19_27pm.thumb.jpg.7d1893bf524142a177dc0d97837bc3c3.jpg
Ok I did as instructed. I added a wall to one side of the cupola, slapped a vent into it, changed it all to wood. Now I can repeat for the other 7 walls.  Almost ready to submit for building  permits. Just gotta draw some details and create my layouts.  I really enjoy this.
wow Eric that is amazing.  I am drawing this one and will actually build it for myself in my own backyard.  Always wanted a gazebo.  Plan to add one wall with a linear propane fireplace and face of stack stone.
I actually did use the regular polygon tool instead of the pyramid as I was already using that for other things.  then I followed the rest of your ideas for the Octagon post.
