Texture Not Showing in Layout/PDF X13
Disharoon
Hello!
I just recently converted to Chief Architect X13. I am trying to export a Layout File to PDF. Every time I do it removes the textures from my elevations. It also does not show the texture while it is in the layout view and sometimes in the plan view. I have tried to resave, send the view to layout again, change line weights, etc, and I just can't figure it out. I am attaching the resulting PDF and the plan file.
FYI to reduce file size for the forum I removed all interior walls and electric from the plans.
Clemson CA Forum.plan Pages from 4626 Clemson CDs 9.16.pdf
It's probably because you're using a Line Drawing technique with shadows on. Switch to a Vector View, then send to layout using Plot Lines.
It does seem to act buggy, but still, you really shouldn't use the Line Drawing technique for elevation or section views.
