DrewFenton Posted September 7, 2021 Share Posted September 7, 2021 Does anyone know why this tip (at link) will not work? https://www.chiefarchitect.com/support/article/KB-03045/displaying-studs-on-an-unfinished-wall.html The main layer still shows up as flat/solid wood vs. seeing the framing/studs. Thank you, DREW Link to comment Share on other sites More sharing options...
Chopsaw Posted September 7, 2021 Share Posted September 7, 2021 Did you frame the wall yet ? See step #7 Link to comment Share on other sites More sharing options...
DrewFenton Posted September 7, 2021 Author Share Posted September 7, 2021 Hi, yes I did. So I can see the framing in 3D with the Framing Overview cam. But the walls look like this with no drywall... Link to comment Share on other sites More sharing options...
Chopsaw Posted September 7, 2021 Share Posted September 7, 2021 That is a little odd. It usually looks like that when it is not framed. You may need to post the plan file if you are in a hurry. Link to comment Share on other sites More sharing options...
DrewFenton Posted September 7, 2021 Author Share Posted September 7, 2021 OK---I just figured it out. I had to turn on Walls, Layers in the camera view. Thank you! DREW 1 Link to comment Share on other sites More sharing options...
