Designer1 Posted August 23, 2021 Share Posted August 23, 2021 Does anyone know the best way to do a elevation view for the island so I can dimension it but not the wall cabinets behind it? Does anyone know how to get chief to recognize certain built in refrigerators in elevation view with the centerpoint lines using the NKBA auto elevation dimensions? For some reason chief is recognizing it as only a cabinet. Thanks! Link to comment Share on other sites More sharing options...
joey_martin Posted August 23, 2021 Share Posted August 23, 2021 For islands use the back clipped cross section tool and crop to fit. 1 Link to comment Share on other sites More sharing options...
Designer1 Posted August 24, 2021 Author Share Posted August 24, 2021 Thanks for the reply Joey. Can you explain the crop to fit tool a bit? I couldnt find the right tool to use to crop it so NKBA auto dimensions just work for that wall. Does anyone know how to get chief to recognize certain built in refrigerators in elevation view with the centerpoint lines using the NKBA auto elevation dimensions? Link to comment Share on other sites More sharing options...
joey_martin Posted August 24, 2021 Share Posted August 24, 2021 I never use the NKBA dims so I don't know anything about that, but the crop is just when sending to layout crop the box to take out any extra floor layers that will show using the back clipped cross section camera. BTW, just using the regular dim tool will find all the centerlines so I don't know what the advantage of using the NKBA tool gives you. Link to comment Share on other sites More sharing options...
Designer1 Posted August 25, 2021 Author Share Posted August 25, 2021 Thanks Joey for the clarification, I appreciate your time and help! Link to comment Share on other sites More sharing options...
