winterdd Posted August 19, 2021 Share Posted August 19, 2021 Sure do wish I could get walls to slide into place in X13 in 3d view. I have to go into a plan view to get this command to work now. Anyone else notice this? Link to comment Share on other sites More sharing options...
Chopsaw Posted August 19, 2021 Share Posted August 19, 2021 That may not actually be close enough to use that tool. Not sure if the tolerances are the same in 3D or not though. Although if it is not close enough the tool should not be available so you may have an issue to send in. Link to comment Share on other sites More sharing options...
winterdd Posted August 19, 2021 Author Share Posted August 19, 2021 12 minutes ago, Chopsaw said: That may not actually be close enough to use that tool. Not sure if the tolerances are the same in 3D or not though. Although if it is not close enough the tool should not be available so you may have an issue to send in. Yeah I thought about that. However I tried different tolerances before and it just won't slide into place. Just once less step to hit in in 3d when I am doing a walk through. Link to comment Share on other sites More sharing options...
