kylejmarsh Posted August 17, 2021 Share Posted August 17, 2021 Somewhere along the way here I found a good roof label macro and modified it to fit my use - which was great up till now that there seems to be a roof label fill which is background color (white) but it covers up the arrow for the roof plane itself. Does anybody have this issue yet and how can we control the label background on a roof label? I haven't been able to find it. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 17, 2021 Share Posted August 17, 2021 Kyle you will likely need to use a Transparent Text Style with a contrasting text color to your roof plane fill but it seems that you also have an issue with your macro or it may just be your font. Place a couple of carriage returns after your macro in the roof label or build a "\n" or two into the macro. Are you getting those results on a Mac ? I was told it was not happening on Mac's. The changes they made in X13 are likely technically correct but they simply do not work with the roof label. Link to comment Share on other sites More sharing options...
kylejmarsh Posted August 17, 2021 Author Share Posted August 17, 2021 Thank you thank you for sending the link to that other conversation - maybe I'll delete this one and jump in over there. I am on a Mac yes - I've been using the \n stack to get it just right - had it before so that the arrow was right smack in the middle of the text! looked so sweet. Ok I will check out that other discussion thanks again Link to comment Share on other sites More sharing options...
Chopsaw Posted August 17, 2021 Share Posted August 17, 2021 3 minutes ago, kylejmarsh said: I've been using the \n stack to get it just right - had it before so that the arrow was right smack in the middle of the text! looked so sweet. That is most likely not possible any more because of the way they have it centered but give it a try so they have all the facts when you send it in. Link to comment Share on other sites More sharing options...
kylejmarsh Posted August 17, 2021 Author Share Posted August 17, 2021 Yeah the trick was to add an extra \n before everything else. Sauce: indx = $tree['roofplanes'].keys.find_index(id) result = "\n" result += areasq.to_s + " sq" +"\n" result += pitch + "\n" result += "\n" result += "Eave: " + eave_fascia_length.to_s + "' " +"\n" result += "Gable: " + gable_fascia_length.to_s + "' " result Link to comment Share on other sites More sharing options...
kylejmarsh Posted August 17, 2021 Author Share Posted August 17, 2021 centered well enough, anyway. you can see it hiding there behind the label Link to comment Share on other sites More sharing options...
Chopsaw Posted August 17, 2021 Share Posted August 17, 2021 4 minutes ago, kylejmarsh said: Yeah the trick was to add an extra \n before everything else. Ok I guess it can be done with transparent text then. Still pretty goofy though even for a default label. 1 Link to comment Share on other sites More sharing options...
kylejmarsh Posted August 17, 2021 Author Share Posted August 17, 2021 I was able to create a new roof label style in text defaults and force it to have a transparent background - this worked well enough so I'm calling it fixed for now. Reminds me of the old 'there I fixed it' blog https://failblog.cheezburger.com/thereifixedit Link to comment Share on other sites More sharing options...
