BuildMasters Posted August 9, 2021 Share Posted August 9, 2021 Can someone please explain why when I add a foundation the program moves the walls from being built on top of the floor system to being build on top of the foundation next to the floor system. How can I change it back? I've attached pictures of before and after. Thanks for the help. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 9, 2021 Share Posted August 9, 2021 There was a similar post last week and it was a Wall definition issue with which layer the platform was assign to build too. still just a guess though since you didn't attach the Plan. M. Link to comment Share on other sites More sharing options...
Crusader103 Posted August 9, 2021 Share Posted August 9, 2021 Go in to your wall settings. I would check my foundation and exterior walls. Make sure that you have your foundation set to build to exterior of your main floor layer, assuming that's what you are trying to align with. Link to comment Share on other sites More sharing options...
BuildMasters Posted August 10, 2021 Author Share Posted August 10, 2021 Thanks for the replies. Here are both the SIP wall details and the foundations walls. Does this look correct? Here is the plan file as well. 330 Rock_Version 2.plan Link to comment Share on other sites More sharing options...
BuildMasters Posted August 10, 2021 Author Share Posted August 10, 2021 Thank you! That fixed it. Link to comment Share on other sites More sharing options...
