5Design Posted August 2, 2021 Share Posted August 2, 2021 Hey Y'all, Any thoughts as to why this is happening. Each wall is set to begin the upper pitch at the baseline (same on the 8' plates). It shows the correct height in the wall dialogue, but it's off by 36". Thanks, 2009 Greenwood LN W Sun Room 5FT.zipFetching info... Link to comment Share on other sites More sharing options...
SNestor Posted August 3, 2021 Share Posted August 3, 2021 @5Design - you have to close the plan file before uploading to Chief. Just a guess...but, it might have something to do with the roof height settings in the "build roof" dialogue. Chief may be moving the roof baseline in order to keep your eaves at the same height. Just a guess without the plan file. Link to comment Share on other sites More sharing options...
5Design Posted August 3, 2021 Author Share Posted August 3, 2021 On 8/3/2021 at 12:05 AM, SNestor said: @5Design - you have to close the plan file before uploading to Chief. Just a guess...but, it might have something to do with the roof height settings in the "build roof" dialogue. Chief may be moving the roof baseline in order to keep your eaves at the same height. Just a guess without the plan file. Expand Thanks, Steve. I thought the plan had loaded (guess I pushed post before it loaded). But it was set to allow lower plans. 2009 Greenwood LN W Sun Room.planFetching info... Link to comment Share on other sites More sharing options...
SNestor Posted August 3, 2021 Share Posted August 3, 2021 @5Design - As Solver states above...the plan you attached does not have the double roof pitch. Looks like you attached the wrong plan? Link to comment Share on other sites More sharing options...
5Design Posted August 3, 2021 Author Share Posted August 3, 2021 Well crikey... let's try this one. Sorry. 2009 Greenwood LN W Sun Room 5FT.planFetching info... Link to comment Share on other sites More sharing options...
SNestor Posted August 3, 2021 Share Posted August 3, 2021 @solver - I didn't get that error message when I opened the plan. Link to comment Share on other sites More sharing options...
5Design Posted August 3, 2021 Author Share Posted August 3, 2021 Well, for whatever reason, it was because I had it set 0" in from baseline. When I changed it to 2" in, it built accordingly. Thanks. Link to comment Share on other sites More sharing options...
