X7 - Custom Backsplash Default Settings
WHDesigns
Go to solution Solved by Kbird1,
Where do I find the default settings for Custom Backsplash in X7 Premier? (I know, I know an upgrade is long overdue!)
Out of nowhere my splash material region defaults to 0" so it does not show the polyline in elevation when I drag my shape.
I can change the layer color and find the line in plan and manually update the material thickness, but I'd like to set my default back to something reasonable but I cannot find the parent default to change it within. I've tried: Defaults > Cabinets / CAD / Material Region / Walls... all without luck.
Thanks in advance!
  • Solution
18 minutes ago, WHDesigns said:
Thanks @Kbird1.  Your's is exactly where it should be but, unfortunately, as mine is "missing" I'll assume it's just a nuance of the older version. Bummer.
don't have the Manual?   from the V7 Manual PDF......
