Some library Items not showing preview
DianaK
New issue. Don't know why but when I select a manufacturer, for instance a paint color, the drop down preview are not displayed. So if I look at Sherwin Williams under "reds", click on that & normally there would be mini icons of all the reds but that is no longer happening. Same thing with tile, plants etc. Is it a setting that somehow got turned off?
Sometimes when panels get moved around or turned off the "Show/Hide Selection Panel" Chopsaw mentioned can be somewhat collapsed.
Try making sure it's toggled on and dragging the two windows apart as shown in the images.  Lemme know if you still have issues and I'll help run it down.
