What is the best way to add Professional Engineer's Stamp to Layout Drawings?
DeltaHome
We need to submit our plans online to the County Building Dept.
I could print the Layout and then have the P.E. stamp each sheet, and then have each sheet scanned, but there will be a degradation of the drawing from that process.
Have the engineer add it to your PDF.  If it is being done under the engineers direction, they can send you a jpeg of a signed stamp and you can import it into your layout.  Make sure they know that you are doing it this way and send them a copy of the stamped version for their records.
