Ray Trace Problem
ramdes22
You can always use ""Control-Tab" to switch between the render view, ray trace window and plan view but to make 3D changes in the plan file you would have to start the render or ray trace over again to include new changes. That is merely the way things are programmed to work.
I often start, view-evauate the ray trace, stop the ray trace, make adjustments several times until I then am satisfied with the look of the ray trace allowing it to finish, it is a process of adjustments and then retry until you get the appearance you desire.
Hi David.. Thanks for the reply... But I used to be able to just hit the del button and that would quit the process so that I may start again...but I can't and have to either wait an hour for it to be completed or shut down chief all together and reopen the file as an automatic saved file.
