Polyline label
Go to solution Solved by Kbird1,
I use closed polylines to measure perimeter lf for assisting with estimating materials. The polyline’s object specification for the number style is set for feet, fractional inches. However, the number style for the corresponding polyline label is defaulting to only fractional inches. For the polyline label, I am using the object specific macro for %perimeter and want the label to display the perimeter as feet, fractional inches. How do I change that?
thanks.
  • Solution
You need to convert the Inches with a Macro , in X12 and X13 we have the Number.Formatter.New technique now ,
which I believe is what Eric is referring you too.
here is the quick play I had, not sure how elegant it is but it works.....
just import it into TMM and then insert into the Polyline Label :
  MHD Polyline Perimeter Label.json
this PDF is some more info gleaned here on the Forum on the New Number Formatter option to use with     .to_xx_xx '
CA Ruby Measurement Class and New Number Formatter.pdf
Mick.
Macro - Text Only:
#Define Number Formatter in Feet-Inch
$NF = NumberFormatter.new
$NF.unit = '\'-"'
$NF.use_fractions = true
def fi(n)
end
# Macro Start
n = (perimeter.to_ft).round(2)
$NF.apply(n)
*** Eric was kind enough to point out that in this case we don't need a Global New Number , so the Code would be :
Solver Polyline Perimeter Label.json
# Eric's simpler non- Global Macro
#Macro Start
nf = NumberFormatter.new
nf.unit = '\'-"'
nf.use_fractions = true
nf.apply(perimeter)
    29829
    MeganB
    MeganB
