Cabinet Schedule vs. Cabinet Numbering
DrewFenton
Happy 4th!  Go America!
Please help as I am going crazy over the cabinet numbering in my plan.  The Cabinet Schedule appears to list the cabinet numbers properly, but the plan view is incorrect and does not match the schedule.
I have tried renumbering the Schedule and adjusting settings in the Schedule as well as the cabinet Label module.  If I choose within the Schedule to display labels, it does indeed show them in the plan correctly, but it also shows the incorrect labels too.
Here is the view (attached as 1.png) if within the Schedule it is set for Callout for Label OFF (e.g. cabinet C36 in Schedule vs. C20 in the plan):
And the view (attached as 2.png) if Schedule setting with Callout for Label set to ON (shows both labels in the plan but they are different!):
And here (3.png) is the Label dialogue within the cabinet itself (nothing changes if I check Automatic Label vs. Specify Label):
Components dialogue (4.png):
Object Information dialogue (5.png):
I really appreciate your help.
2 hours ago, DrewFenton said:
Solver, yes!  I am so thankful for your help.  The newer cabinet schedule had the incorrect numbers and the original schedule is correct.  Thanks again so much---I will just stick with the one schedule.
I'd recommend keeping your Schedule in it's Own CAD Detail for more control on sending to Layout and not slowing Plan Views down.
If you make these ONCE in your Template Plan you will never have to do it again and they will update as you draw and place objects.
