Automatic dimensioning for wall stud spacing in elevation view
waxahachie
@waxahachie  You are being more than a little bit disrespectful when two professionals take time out of their day to help you out with some good advice.
You can use a standard elevation camera and switch from the Section View layer set to the 3D Framing layer set but you will need overlay a cad detail from view in order for your dimensions to have something to snap to.
If that does not work for you.  This is the place to have a respectful discussion about it but not to slam volunteers with downvotes.
