waxahachie Posted June 29, 2021 Share Posted June 29, 2021 Is there a way to get wall stud spacing dimensioned in elevation view, similar to when you generate an elevation for cabinets ?? 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted June 29, 2021 Share Posted June 29, 2021 You can get an entire framing layout using the Wall Detail tool and send that to layout with dimensions if you like. 1 1 Link to comment Share on other sites More sharing options...
winterdd Posted June 29, 2021 Share Posted June 29, 2021 build framing.....right click on wall.......open wall detail 1 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted July 1, 2021 Share Posted July 1, 2021 @waxahachie You are being more than a little bit disrespectful when two professionals take time out of their day to help you out with some good advice. You can use a standard elevation camera and switch from the Section View layer set to the 3D Framing layer set but you will need overlay a cad detail from view in order for your dimensions to have something to snap to. If that does not work for you. This is the place to have a respectful discussion about it but not to slam volunteers with downvotes. 1 Link to comment Share on other sites More sharing options...
winterdd Posted July 1, 2021 Share Posted July 1, 2021 What on earth is his deal? A downvote? Link to comment Share on other sites More sharing options...
