anvl369 Posted December 10, 2014 Share Posted December 10, 2014 Is there a way to change the actual thickness/width of the sides of a cabinet box (gables). My manufacturer uses 5/8" gables and I notice that CA cabinet sides are 3/4". I looked through the cabinet preference .dbx, but could not find how to change that particular item. I can change the height of the horizontal separations, but am unable to change the thickness/width of the gables. My plan is using frameless cabinets, and I have 2 cabinets that are open front cabinets. I need to be able to show the correct gable width, in order to show precise interior cabinet dimensions. Thank you Link to comment Share on other sites More sharing options...
MarkMc Posted December 10, 2014 Share Posted December 10, 2014 No, there is not a way to change that. For just a few cabinets you can fix it in layout-(this is for Premier- won't work in Interiors) easiest to first draw cad in elevation I drew a pline rectangle, sized it and point to point to move to corner of the cabinet- have to zoom in since it doesn't snap. Then transform replicate/copy by a factor of 0.9, then adjust the dimensions to 5/8. Once in layout use tools,layout, edit layout lines(not available in interiors) and delete the original lines at 3/4" then you have to adjust all the shelf lines to meet you gable. I thought there was a way to resize a pline box by a dimensions but can't find it- anyone know how to do that?? Link to comment Share on other sites More sharing options...
anvl369 Posted December 12, 2014 Author Share Posted December 12, 2014 Thanks Marc, I am running Premier...that seems like it still a lot of work...will send that off as part of my 'wish list' . Link to comment Share on other sites More sharing options...
