Korel_Design Posted June 21, 2021 Share Posted June 21, 2021 I have a floor plan that is too long to fit straight on the layout so I need to rotate it. Only , my dims flip to the other side of the line. I really want to keep the dims on the side of the line I drew them on. Is there something that can be clicked to prevent the dims from flipping when rotating in layout? Yes, I did look. X12 in Win10 Link to comment Share on other sites More sharing options...
Korel_Design Posted June 22, 2021 Author Share Posted June 22, 2021 Apparently, there is no control over flipping dimension numbers when rotating a floor plan to fit on a Layout Sheet. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 22, 2021 Share Posted June 22, 2021 If you are really stuck you can rotate your layout sheet and title block but it is quite a hassle. I would have thought you could lock the dimensions by now. Link to comment Share on other sites More sharing options...
Korel_Design Posted June 23, 2021 Author Share Posted June 23, 2021 Thanks for that suggestion. This only happens in less that once in a blue moon. It's not the end of the world. I can lock the regular text such as various notes on the plan. I can not lock the dims. JK Link to comment Share on other sites More sharing options...
