Joe_Carrick Posted June 9, 2021 Share Posted June 9, 2021 Here's a Library with "Intelligent Roof Pitch Triangles". They are actually Moldings - here's how to use them: Place the Molding Profile in Elevation or Section views. Adjust the vertical line's length to (3) times the pitch number of your roof plane (because the triangle is 36" wide) 12" = 4:12 15" = 5:12 18" = 6:12 etc This will change the vertical dimension to match the roof pitch. You may need to adjust the position of the label slightly. This is something that has been requested many times. Now that we can have labels for polylines and store the polyline in the User Library this works fairly well. Roof Pitch.calibz 2 3 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 14, 2021 Author Share Posted June 14, 2021 The attached macro will need to be downloaded and installed. For some reason the macro isn't being included in the calibz file. roof_pitch.json Link to comment Share on other sites More sharing options...
Chopsaw Posted June 15, 2021 Share Posted June 15, 2021 Joe, I think it imported but I can't find the .calibz file in my library or even search it. What did you call it ? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 15, 2021 Share Posted June 15, 2021 Thanks Eric, I downloaded it again and it worked this time. File must have been corrupted originally. Link to comment Share on other sites More sharing options...
