BillsburgChief Posted June 4, 2021 Share Posted June 4, 2021 I have a 8' ceiling second floor that cantilevers 2' out over the first floor that has a 10' ceiling, also on the first floor I have a front covered porch that I want to have a 9' flat ceiling. When I lower the porch ceiling it also lower my second floor because of the space below the cantilever, is there any way to do this w/o lowering the foor above? Plan is posted. 21-012 Crown Residence.plan Link to comment Share on other sites More sharing options...
SNestor Posted June 4, 2021 Share Posted June 4, 2021 You can achieve this in Chief...but it is a bit time consuming. Adding a ceiling plane as Eric suggested above it probably the quickest method. I've attached a plan so you can review what I did...and a few screen clips. I created a room below the 2nd floor cantilevered area...and made adjustments to that "room" to the ceiling structure. Open the attached plan and review. In the attached plan I also changed your deck/porch wall to a railing wall, post to ceiling and added square posts. No need to use solids for posts. You may want the posts in specific locations...and there are ways to achieve a specific column/newel spacing in Chief. CrownResidence - Nestor Edits.plan Link to comment Share on other sites More sharing options...
