Migaloo Posted May 25, 2021 Share Posted May 25, 2021 Can't seem to get my roof to build automatically. I have obviously overlooked something. I have made some attempts to just manually draw it but it is never quite right. Any help would be appreciated. WV1.plan Link to comment Share on other sites More sharing options...
builtright3 Posted May 25, 2021 Share Posted May 25, 2021 I always start with this on automatic An then put the walls with the lower pitch and add the lower pitch roof manually. File is attached: you should be able to finish up. Untitled 1.zip Link to comment Share on other sites More sharing options...
builtright3 Posted May 25, 2021 Share Posted May 25, 2021 48 minutes ago, Migaloo said: Can't seem to get my roof to build automatically. I have obviously overlooked something. I have made some attempts to just manually draw it but it is never quite right. Any help would be appreciated. WV1.plan 3.42 MB · 4 downloads So in other words; If you shape the house so that you can get the main part of the roof the way you want it you can do the automatic roof build and then change your walls around and add the other roofs manually. At least that's the way that works best for me. There are other ways to get auto roofs to work for you but its more work I think unless you do it a lot and you get really efficient at it. Like others on this forum that are way more experienced than I am. Depends on what your needs are Link to comment Share on other sites More sharing options...
Migaloo Posted May 25, 2021 Author Share Posted May 25, 2021 Thank you all for your suggestions. I believe I can get it now. Link to comment Share on other sites More sharing options...
