LCDesign Posted May 10, 2021 Share Posted May 10, 2021 I am using Chief X12. I have "Rotate Text With Plan" checked everywhere I can find it. Regardless of whether I rotate my plan using Rotate Plan in Tools or if I rotate it manually on my layout, my text does not rotate. How can I fix this? Link to comment Share on other sites More sharing options...
mattheg Posted May 26, 2021 Share Posted May 26, 2021 On 5/10/2021 at 11:52 AM, LCDesign said: I am using Chief X12. I have "Rotate Text With Plan" checked everywhere I can find it. Regardless of whether I rotate my plan using Rotate Plan in Tools or if I rotate it manually on my layout, my text does not rotate. How can I fix this? In Chief X12 I can rotate my plan view (Tools; Rotate Plan View) and most texts like cabinet labels rotate fine...the Elevation view markers don't Link to comment Share on other sites More sharing options...
DoriniHomes Posted June 2, 2021 Share Posted June 2, 2021 Is there a way to 'flip' the entire plan vertically? To do so, I reversed the plan, then rotated the plan 180 degrees, but like LC Design, all of my labels are now reversed. In other software I used, there was always a flip plan vertically or horizontally tool, but I can't seem to find it on X12... Thanks for any suggestions... Link to comment Share on other sites More sharing options...
MoeGia Posted June 3, 2021 Share Posted June 3, 2021 You can use 'edit area all' to flip a plan horizontally or vertically in one move (I flip about a current point located at the center to keep things in the same 3D space). I think you'll have the same issues with your labels not flipping. I'm not at my computer to check, just wanted to give another option. I still have text that I need to flip manually. Link to comment Share on other sites More sharing options...
